What bore is the carbs on a VTR 1000?
Re: What bore is the carbs on a VTR 1000?
buzzer wrote: Sat Nov 30, 2019 2:40 pm Engine installed in the frame! :D I cant think of any bike that is so simple to get the engine in the frame… I remember three of us struggling to get a Laverda 1000 lump in a freshly painted frame years ago, trying desperately not to mark the paint!
I see what you mean regarding how easy it is to fit the engine into the frame :thumbup:
It's starting to come together now :clap:
total left field question, i know these carbs are big but has anybody ever bored a set to say 50 mm and tried them?
mik_str
Post by mik_str »
fabiostar wrote: Mon Dec 02, 2019 10:47 pm total left field question, i know these carbs are big but has anybody ever bored a set to say 50 mm and tried them?
I've often wondered the same thing...
buzzer
Post by buzzer »
I wanted to change the colour of the rear spring from yellow to red, and tidy up the shocker… which meant getting the spring off! its no easy task as its VERY strong. I drew up a couple of plates on CAD and sent the drawing to the laser cutter… few days later these came. made it an easy and safe job!
mik_str wrote: Tue Dec 03, 2019 4:32 am
iv a few carbs bits sitting about here and just to see if its possible i think il mount a carb body in the lathe, just to see :thumbup:
buzzer wrote: Tue Dec 03, 2019 9:21 pm I wanted to change the colour of the rear spring from yellow to red, and tidy up the shocker… which meant getting the spring off! its no easy task as its VERY strong. I drew up a couple of plates on CAD and sent the drawing to the laser cutter… few days later these came. made it an easy and safe job!
I like your spring compression tool, at least no chance of it slipping off and flying somewhere.
fabiostar wrote: Tue Dec 03, 2019 11:03 pm
8) :thumbup:
Good luck Rob,
buzzer
Post by buzzer »
well its back on its wheels... I am pleased at how the Multistrada footrest conversion has worked out, it brings the foot pegs forward quite a bit and should achieve the riding position I was looking for.
Just about to rebuild the brakes... the fronts are fine and the pistons came out easily, but the rear caliper is seized absolutely solid! I have left it connected to the air line overnight, but the pistons have not moved yet!
Not sure about the gold discs on the front... they may have to be changed... we will see...
What a top job. It is going to look fantastic!!! Oh to have the space and tools, not to mention the skill to use them. Me I can just about change a spark plug 😂😂
buzzer wrote: Thu Dec 05, 2019 2:04 pm well its back on its wheels... I am pleased at how the Multistrada footrest conversion has worked out, it brings the foot pegs forward quite a bit and should achieve the riding position I was looking for.
You're making good progress :thumbup: :clap:
That bike is looking really nice
That bike is good enough to sit in any bedroom :thumbup: :thumbup:
buzzer
Post by buzzer »
Any of you guys tell me where the large and small black pipe goes to on your VTR's?
large one is the diaphragm vent to atmosphere .. on the storm it goes into the airbox so it is breathing filtered air.
I am not sure about the small one, but I think it is the float bowl vent to atmosphere
buzzer
Post by buzzer »
perfect! thanks guys :thumbup: :thumbup: :thumbup:
