Just in the process of fitting a set of standard Blade forks
Can anyone recommend base settings and also CHEAP mods?
Cheap as in different weight oil, springs are out of budget at the moment
Ben
Fireblade forks setup and help please
- Stormin Ben
Ben/Welshy
Just had a look and the following are the settings i got off racetech for standard 96/97 blade forks:
For fast road riding:
Preload - 4 lines showing
Rebound - 1.5 turns out from fully seated
Compression - 1 turn out from fully seated
For track use:
Preload - 1 line showing
Rebound - 1 turn out from fully seated
Compression - 0.5 turn out from full in
Hope this helps lads.
If you want the settings i'm using for my blade forks with ohlins springs and racetech valves give me a shout.
Cheers[/u]
For track use:
Cheers[/u]
Si
Fireblade forks
When you fit them check the steering stops on the bottom yolk mine are fouling the headlight /fairing bracket giving less steering lock and the pin won't engage on the lock itself! (hopefully fixing this today) The horn needs moving as well, all I done was drilled an 8mm hole in the horn bracket about halfway along its lengh then turned it the other way round with a few washers and a longer bolt to clear the lug on the bottom yolk!
Warren.
Warren.
- Stormin Ben
Re: Fireblade forks
Cheers for that Warren.
The lock-stops are fine on mine.
I haven't refitted the fairing yet so I'll look out for the horn (ooh-err!!)
Also didn't have any problems with the steering lock, other than getting it off the old yokes!! (Still got a swollen black knuckle from that one)
Now all I've gotta do is get the new front tyre scrubbed in so I can test the forks properly (2 front slides while checking for travel on the brakes has put me of trying harder - YET!!) but the feeling from the new forks is noticeably better already - WOOHOO
Ben
Ben
fireblade forks
All solved
Mine must have been from a different year Blade, filed a notch in the lugs on the bottom yolk and I had to lower the steering lock by 3mm, this was because I fitted taper roller bearings in the headstock and they are a bit deeper than std and move the yolks further apart
