Dazjm
Posts: 164 Joined: Sun Sep 23, 2007 10:32 am
Post
by Dazjm » Thu Nov 15, 2007 1:39 pm
Any tips on how to get em off, without destroying either tool or cap?
A case of spraying liberally with "anti stuck fast spray"?
solorider
Posts: 217 Joined: Wed Oct 03, 2007 7:28 pm
Post
by solorider » Thu Nov 15, 2007 4:31 pm
mine was a bit mullard,someone used a chisel to turn the cap and i did the same but im afraid you will damage the cap,they are available from david silver spares
Dazjm
Post
by Dazjm » Thu Nov 15, 2007 6:26 pm
Ahh, glad to see im not alone then.
Was gonna change cct today, til those and a seized air filter trumpet screw halted my progress.
Stratman
Posts: 2656 Joined: Mon Dec 01, 2003 10:55 pm
Post
by Stratman » Thu Nov 15, 2007 7:01 pm
Yep.Made of cheese. I used a centre punch to shift mine but you need a new one if you've tried an allen key first as it will have chewed up the hole
solorider
Post
by solorider » Thu Nov 15, 2007 7:48 pm
Dazjm wrote: Ahh, glad to see im not alone then.
and im not alone ,my air trumpet screw also siezed
Dazjm
Post
by Dazjm » Fri Nov 16, 2007 12:52 pm
Does anyone know if i should have a gathering of engine oil behind the inspection hole cover? I took the fron off the alternator/stator cover thingy, and obviously oil was gathering on the bottom of the flywheel, and coating the stator.
Is this normal?
