Fitted a 21 rear at the Bulldog this year, and it's still on.
Ride all year, and use it for work, so although i haven't logged the mileage it's lasting longer that the 020's I usually run.
But is it me, or is the middle bit damned hard an slippy?
The roads have been awful since the leaves started dropping, but the rear breaks away at the slightest provocation.
'Nother thing, when following changes of level or ridges running along the direction of travel, (like in the middle of the road, where they've surfaced one side then the other) it tracks horribly.
Means I have to concentrate hard when filtering, as the bike wanders towards the cars I'm passing.
Got to say, I was impressed at first, on warm roads, but now I'm not so sure....
Anyone else got any feedback?
BT021's
- LotusSevenMan
Know what you mean about 'tramlining' and especially over the tarmac 'join' in the centre of the road when filtering but this is as they get a bit worn and profile flattens a bit (well it is for me as I do a fair amount of motorway running etc). Fine when only about 200 miles on and scrubbed in so ????
LSM
LSM
- LotusSevenMan
Apologies to Bridgestone 021 rears
Holding my hand up to unfair judgement on the Bridgestone 021 rear.
I was blaming the 021, but I changed it for a Mich 2CT (they didn't have the Bridge in stock at the time) and it's still doing what I described above.
Turned out to be the 020 front, which wasn't worn down to legal limits (had about 2-2.5mm) but when I changed that to a Mich 2CT to match the rear the handling came back.
So maybe the mix of 021 rear and 020 front was to blame? Dunno if anyone else is running this combo?
- Fireman on a Storm
Be interested in a report on the 2CT's. I'm thinking of putting them on next. I have Avon Storm ST's on at the moment and they've been great, but I fancy the 2CT as I plan to trash the crap outta it over summer.
I had 014's which were good, but I mullered them in 1000 miles, so not buying them again.
I have a real dilemma when it comes to tyres. I have to balance the fact that i am fed up with buying a new rear every 1800 miles,
with the point that i need a lot of grip. I am going to try them pilot thingys with the dual compund rubber next. What are they called then?
Interesting someone mentioned spinning the rear up in this weather. I have the delight of mine doing that all year round, regardless of the weather
Welcome to the world of 170 bhp.....
I am feeling that Kitch 014s will be swapped for 021s next time around.Kitch wrote:Be interested in a report on the 2CT's. I'm thinking of putting them on next. I have Avon Storm ST's on at the moment and they've been great, but I fancy the 2CT as I plan to trash the crap outta it over summer.
