SP1 clocks on the firestorm
genisis
Post by genisis »
Hi All,
A bit of a random question but do you think the SP1 dash will fit on the Firestorm.
I've check the basic functions and they are the same oil light fuel light etc
cheers
Matthew
rst steve
Post by rst steve »
I have often wondered whether this is possible as i would like the sp1 dash. The vtr one is all electric but i am sure that there is a stumbling block somewhere that prevents the conversion from being done. Will have to look into this one. :wink:
rst steve
Post by rst steve »
Just found the rc51 wiring diagram so will see how differant it is from the vtr one.
solorider
Post by solorider »
if it is anything like the blackbird when it went digital then it could be fitted but honda took the temp gauge signal fom the ecu not a sensor
Kitch
Post by Kitch »
I'd kinda doubt it. With the SP's being injected, they have all sorts of electrickery on board as it is and the dah will likely tie into those.
It could be possible to make it work, but its probably a lot of hassle. Why would you bother?
Seriously, a proper nice race dash that looks nicer, has more functionality and will be way easier to plumb in can be had for same money as a second hand SP dash.
Acewell, Trailtech and Racelogic are 3 off the top of my head.
Either PM or email Daz (Stormsmasher) he should be able to advise you on if it's worth doing or not :!:
See link:-
http://www.vtr1000.org/phpBB3/viewtopic ... +firestorm
stormsmasher
Post by stormsmasher »
I tried and failed mate spent ages messing but still could not get all the functions to work.
If I remember right I managed to get the speedo and all the warning lights to work but could never get the rev counter to work and the temp gauge was wrong but that could be fixed if you managed to find a way of fitting an SP-1 temp sender unit to the VTR.
Hope this helps
Daz (lurker these days)
RedStormV
Post by RedStormV »
FSM slightly off beam, if you're referring to the 'Guinness' fightered Storm, he had all of it working apart fom the rev counter as Daz has also mentioned managing.
I only know cos I e-mailed him to ask him at the time.
