My take on the old CCT problem!!!
LotusSevenMan
Post by LotusSevenMan »
Decided to modify the std Honda issue CCT's and turn them into CM's........................... "Chris's Monkeys" (to avoid Trademark violation......... but you get the drift!).
See:-
I think it should work perfectly well and cost really is neglible.
What do ya think fellas? All constructive comments appreciated (either good or bad!)
LSM
Stratman
Post by Stratman »
Easy enough to get a selection of rubber o rings from B&Q for a couple of squids.
I wish I'd had this idea before spending the dosh on the APEs. To all intents and purposes this will do exactly the same job!
LotusSevenMan
'O' ring IS in place. I didn't realise the other ones had them and wondered if it was overkill as the front cylinder NEVER gets oil up there (which is why IMHO they fail first normally) and the rear one that does should not leak past a well tightened nut etc but I was being careful. Oh good!!! :D
Good one Chris (LSM) :D 8) 8)
Not expensive to do either, if you have the right tools :!:
LotusSevenMan
Just need a 'Mr Bolt' or whatever nearby!!! :roll:
Stratman
Post by Stratman »
You mean Bernie?
Left a bit, right a bit.....
LotusSevenMan
Wouldn't know what you were referring to?
Far too young I am. Hang on.
"Hey dad, read this".
He says it's
"Something to do with it being a long shot and a golden opportunity"?
Dream on LSM!!!! :roll:
