My winter/spring mods are moving along. After consulting Roger Ditchfield, I elected to go ahead with the CBR900RR front-end (which means I'll be looking to part with the SP-2 forks I bought). He kindly gave me valving and spring specs to use so I am just waiting on the seals I ordered before sending the tubes off to a buddy's place to have the work done.
I am still looking to find a set of Helibars for the CBR forks but will likely resort to installing a set of handlebars instead (Helibars and the rest of the set-ups that would give me the desired riding position are just too damned expensive). I will be having the steering bearings replaced with tapered rollers at the same time as the forks get installed. In the braking dept., I picked up a set of HRC hard bite pads to fit to my SP-2 calipers and may also add an R1 radial MC.
I completed my 2-1 exhaust conversion. I had picked up a Blue Flame dual port high-mount can for a 98 R1 on eBay and, after some cutting and praying, managed to fit the link pipe so as to mount it up to my Micron support. I cut the headers at the joint of the two pipes and cleaned out the welds with the dremel before re-wrapping the pipes. I just finished snuggling everything up on the exhaust and, well, I had to fire it up, he he Let's just say there is a nice bark to the ol' girl now The Blue Flame can is about 3" shorter than the Microns and it is alone in doing the job now. It should sound sweet out on the road
Incidentally, I found the dyno chat below from a chap who also did a 2-1 conversion. I am looking forward to firing it up to see how it runs.
I got my PVM wheels back from the powder coater and they look awesome (fire-engine red). I just picked up new C3 bearings with low-friction seals and am looking forward to having those installed too.
That is all for now. Can't wait to get the rest of the mods out of the way now (and for some snow to melt too) so I can get out and ride....
