oil
oil
hiya new to it all but which oil fully or semi synthetic ? been running fully for last two changes , but the engine seems to be noisier ,but it revs better ! doin ccts cos i got paranoid reading about them , cheers
- clayderman
cheers did not get clutch slip just a noisier engine , must get some louder pipes and better ear plugs
going to go back to semi putoline just to give it a try, wife swears by it in her raptor thou ,then again she allways swears , mostly when i want more bits for the storm , has that fella still got cct springs for sale or is just as well to go to dave silverfor complete units ,
that used to be the problem a few years ago,nowadays you can normaly mix semi,fully and mineral with no problems but if using an inferior oil it is recommended you change the oil to give the longer service intervals.RedStormV wrote:This has been asked answered before somewhere but haven't most?
Anyways, Motul Fully Synth - no clutch slip 25K
Only real advantage of semi is that you can bang anything in if you run low and can't get fully. IMO.
HTH
