Bobbins???
topper
Bobbins???
Post by topper »
Hi there stormers, does anyone use crash protection bobbins, are they anygood/worth buying/fitting? :? Also the prices seem to go from £15 up to £100 wots goin on there :?:
Stormin Ben
Post by Stormin Ben »
In order of price
The £15 ones on ebay screw into the fairing mounts
As these are made out of kit-kat wrappers the first thing they're gonna do in a crash is bend/ break so absolutely no use whatsoever
Motrax ones bolt into the rear engine bolt and have a bracket to clear the fairing
IMO they are too far back and I used to clout my knees on them when hanging off
HOWEVER a mate crashed his Storm at Cadwell with these on and only snapped the brake lever tip off his rearsets and ground his carbon engine cases
R&G ones go straight into the engine mounting bolt and require the fairing to be drilled. While this is not a major problem, it does mean that taking the fairing off is no longer a 5 minute job
Rhencullen do a set that sit further forward, have a much sturdier bracket and also clear the fairing
I've had them on my bike for 6 years and have been really pleased with them
Hope this helps
Ben
But its not a very good one!
RedStormV
Post by RedStormV »
Stormin Ben wrote: R&G ones go straight into the engine mounting bolt and require the fairing to be drilled. While this is not a major problem, it does mean that taking the fairing off is no longer a 5 minute job
Got R&G on mine - don't add more than a couple more minutes to removal / refit or fairings.
Drilling the fairings is pretty straight forward too - IMO
Removing the engine bolt to put the R&G one is took the most time - but I don't think it had ever been out till I removed it.
Check out the testimonials on the web.
Worth the extra few quid when it's saving the plastics - Thankfully not tried this bit out.
HTH
chuxsta
Post by chuxsta »
my bad you said bobbins...
hey.. easy mistake to make..
RedStormV
Post by RedStormV »
Not even worthy of a response
Doh!!!!!!!
topper
Post by topper »
Thanks for that peeps, loads of info as per usual GR8 site :lol:
Stormin Ben
And if you're interested mine are up for sale
£110 worth of Rhencullen ones for £40
http://www.vtr1000.org/phpBB2/viewtopic.php?t=11122
storminateacup
Post by storminateacup »
Ben you have a PM for bungs.
I was born with nothing and I still have most of it left.
