forks,
chuxsta
forks,
Post by chuxsta »
apart from phoning the previous owner is there a way i can find out if he changed the front end susp springs?
as i have never road a storm i dont know what stock springs and aftermarket ones feel like.
i did read the stock ones can bottom out under breaking..
Beamish
Post by Beamish »
Mate, does it matter? If you throw your bike about and are happy with the feel of the forks under heavy braking then who cares :lol:
chuxsta
Post by chuxsta »
well no it doesnt matter,
i was just curious if there were tell tale signs if it has been done..
cause the guy might have done it prior to selling it.
Stormin Ben
Post by Stormin Ben »
Take one of the fork tops off CAREFULLY!!
Then remove the spacer and spring
If the springs have been replaced they should have a weight figure on them (0.95kg/mm will probably read 9.5 etc)
If there's nothing written on them then odds are they are standard
But its not a very good one!
warby221
Post by warby221 »
Stormin Ben wrote: If the springs have been replaced they should have a weight figure on them (0.95kg/mm will probably read 9.5 etc)
not 100% right that Ben I had I think hargon springs in when I got the bike no fig on them but the wind is a lot tighter than standard and there's no fork spacer at the top as the springs are longer
It just yer better kit that has the weight fig on them
