It was only 1 i needed,cos mate had gave me a new one,pkn pyramid did replace it free of charge,but dont think it's there fault.He only had 1 at the time,cos the previous ones he sent were EXACT same as the honda ones i bought.
Honda would not change the genuine oil seals i bought from them,they agreed something was not right,that they were slacker than the pattern part,but couldnt explain it.In my opinion they wernt very helpfull,kinda implied my forks wernt standard,which they are.
Forget Honda part no's and equivalent, it's all to do with the numbers stamped on the top of the seals ,take the numbers from the top your original seals,this is the numbers you need to qoute when ordering new ones,and if the seals you are replacin have 2 tension springs make sure you get same
