will they fit?
chuxsta
will they fit?
Post by chuxsta »
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=015
i dont always believe what i read..... but the seller claims they will fit the storm...
true or false? or any other input is appreciated...
I've been caught out by these before....
the hole on the fairing is quit elarge, and needs the largest size indicators in the cats-eye style to cover it. Because of the contours of the fairing you'll probably get a slight gap at the fornt- annoying but not really noticeable.
Ask for the measurements- then you can run a ruler over the hole and check for sure.
There's three sizes in the M&P catalogue- onlt the largest ones cover the hole properly.
genisis
Post by genisis »
I have some of those on mine they do fit however there is nothing to secure them in properly so i end up have to pop them back into the fairing when i wash the bike etc.
would be okay if you made a small rod on the back to bolt it onto,
The only other problem is there are almost impossible to see from the front.
chuxsta
Post by chuxsta »
well for me to even have indicators and mirrors is a first so it dont really matter if they are visible from certain angles...
gilson
Post by gilson »
Is that you spining the back wheel?!!!
