Rattle, Rattle, shite
Hi all
Well I could have gone out on the blade but went out on the storm
Coming round a corner and I heard a rather loud rattling from the engine, pulled over, stopped the bike and left it a few minutes
Fired her up again and it.s rattling like fook at the front of the engine and popping and banging (like on overrun)
Is it the tensioner gone ????
The bike has not been rattling up till now and running fine
HELP
Rob
HELP
Rob
Thanks for the replies folks
I'm gonna have a look at it the weekend, I'm reasonably ok with the tools as I do most the work on my track bike, saying that this is the first twin I've owned but I do have a factory manual for it
A few questions
1. Is it adviseable to change both cct at the same time
2. If the front (very much souns like the front) has gone will it have thrown the timeing out and if so do I just re-time it as per normal
3. anything else I should be looking for
4.Where is the best place to get new cct's from
Cheers Rob
PS
I'm really pissed off as I was just getting used to the bike and really enjoying riding a v-twin
A few questions
Cheers Rob
PS
- yorkylancs
Mines a bit rattly at the front,it seems to come from the left hand side.So i ordered a new one from my local dealer,he gave me a price of about £60.I am sure Dave silver does them for about £30,might be worth a look.If you are doing the front,it is as well to do the rear,for piece of mind.Took the risk with mine,and went to donny this weekend,but its only a matter of time.......!
1. Why not, you'll have most of the bike in bits anyway.
2. If your saying it's backfiring now then it sounds like the chain has jumped a tooth or 2 and knocked the timing out. Don't bother with the manual, follow sirch's post at the top of the workshop section for a step by step guide.
3. Just hope the valves and piston haven't met.
4. David Silver seems to get the thumbs up.
Today I feel in a helpfull mood, I promise not to slag anyone off. I'll give it till lunchtime
Rich.
[quote="cupasoop"]
quote]
Are you saying that I wont have to re-time it but can just follow sirch's guide
Rob
quote]
Rob
So if the timing marks line up on the rear are you saying that the timing marks will be inline on the front (by following the guide without removing the front cover)cupasoop wrote:No, follow the guide. It shows you how to set up the timing marks to change the cct's. If they dont line up then the timings out and will need adjusting.
Rob
The back and front cylinders are timed independently as they use separate chains
so the timing needs setting for not only the cams to the crank but also front cylinder to back cylinder as you could have the front and back timed 180 degrease out follow this link and start from there
http://www.vtr1000.org/phpBB2/viewtopic.php?t=8326
also here's what i got of roger of rev racing
VTR CAM TIMING PROCEDURE
WITH BOTH FRONT CYLINDER AND REAR CYLINDER CAMSHSHAFTS REMOVED (Starting from scratch)
1) Turn C/shaft until FT appears and lines up with the mark on the cover
2) Fit FRONT CYLINDER Exhaust camshaft with the mark FE on the exhaust camwheel level with the c/head and at the front of the bike with the cam chain tight - RIP TIE the chain to the wheel
3) Fit FRONT CYLINDER Inlet camshaft with the mark FI on the camwheel Level with the C/head and to the rear of the bike - RIP TIE the chain to the wheel
THE CAM LOBES WILL NOW BE POINTING AWAY FROM EACH OTHER
4) Fit the cam caps and CCT - CUT THE RIP TIES
5) TURN THE C/SHAFT ANTI CLOCKWISE 270 DEGREES until RT appears and lines up
6) Fit REAR CYLINDER Exhaust Camshaft with the mark RE on the camwheel level with the c/head and at the rear of the bike with the cam chain tight - RIP TIE chain to wheel
7) Fit the REAR CYLINDER Inlet cam with the mark RI on the camwheel level with the c/head and pointing to the front of the bike -RIP TIE chain to wheel
THE CAM LOBES WILL NOW BE POINTING TOWARDS EACH OTHER
Fit cam caps and CCT - CUT THE RIP TIES
- LotusSevenMan
