stranded
clack
stranded
Post by clack »
Okay guys, I have absolutely no mechanical knowledge so any advice would be gratefully recieved.
On the way to work this morning, covered 16 miles out of 17 going along fine when the bike dies.
Still have power to clocks and lights etc. When I try to start the bike it clicks, sounds like it coming from a little box tucked inside the fairing under the seat just back from the rectifier.
Any ideas?
Thanks in advance.
cupasoop
Post by cupasoop »
Check the main feed to the starter motor down beside the oil filter. Catches all the crap thrown up by the front wheel and can corrode.
Rich.
lee67
Post by lee67 »
sounds like the starter solenoid...give it a good clean and cover in wd40..normally cures it
clack
Post by clack »
Thanks everyone, I'll do some more investigation today. I have however checked the battery terminals, fuses, side stand and kill switches all of which seem to be okay.
storminateacup
Post by storminateacup »
Check volts across battery, if below about 12.5v wont start it, V twins need good batteries. Charge battery refit and check rectifier output, should be no more than 15.5v at 5k. If it is rectifier is fcuked and so is the battery.
I was born with nothing and I still have most of it left.
pariah
Post by pariah »
Battery should be ok as bike was already running,
I would go for the rectifer/charger. Mine went like that and it eventually cooked the battery. Make sure you change for the metal finned one. This should solve the problem.
clack
Post by clack »
thanks again. I've ordered a multimeter (can't believe how cheap they are these days!) so will have a look. Having read quite a few other posts on the forum looks like its potentially the R/R or the starter solenoid.
clack
Post by clack »
well looks like its a can of beer to cupasoup as the cable connected to the front of the motor has corroded clean through.
Good call as I would never have thought to look there.
Now, is it an easy replacement or do I need to take it to a stealer? I'm happy to strip body work etc. and am working on the assumption its only a case of changing an old cable for new. Guess the main issue is likely to be getting the old corroded cable end off and getting the new one on.
I'm having a look at the haynes manual when it downloads, shortly.
RedStormV
Post by RedStormV »
Eyup duck
Is it the main feeder cable to the starter motor that's gone?
Item 5 above?
If so then if possible replace the crimped ring connector on the end of it with a good quality replacement one. Much easier, and cheaper than replacing the whole cable.
If your rubber cap is still in good nick, then fill this with good thick grease before re-fitting.
Had a similar problem a while ago, terminal had loosened, was a pig to start and sometimes just got 'click' from starter relay too.
Another big clue is that when it's loose, smoke and a strange smell eminate from the front end as the cable gets damned hot!! 8O
Graeme.
clack
Post by clack »
Yes the main feeder cable has completely corroded through just above the connector. The rubber cap is crispy to say the least so it was probably verrrrrrry hot at some stage. I need to have a proper look, and see what can be done about the connector.
there's a cable on fleabay at the moment for a tenner which isn't too bad but changing the connector only would save me the agg of routing a new cable.
thks.
cupasoop
Post by cupasoop »
:D Bellhaven Best please.
Check you can get the connection off the starter motor now.
Rich.
RedStormV
Post by RedStormV »
Timbo wrote:If you go for the connector only option, crimp it then Solder it as well.
Dammit, knew I'd missed summat! Pah! :oops:
Glad you're here to support me Tim :D
Not sure about sourcing connector, but it wants to be good and thick, as Tim says carrying a lot of current. Don't want to be one of those flimsy alloy jobs from a crimp set. Brass or Copper alloy if you can get one.
Not sure Halfords etc will do one , but a good motor factors probably will.
Perhaps look up a local auto electrician if ou've one nearby and try blag a good one from them - make sure they know it's for a starter lead though.
yorkylancs
Post by yorkylancs »
You might want to take the end cap off the starter,and have a peek inside.Last time this happened to me,not only the cable burnt out,but the bolt assembly it attaches to.It got that hot that it melted the brush plate mount as well.I put a new cable on but got nothing,just the clicking from the starter solenoid,had to get a new starter.Best thing to stop this is to fit a fenda extenda,or make a cover to stop any crap getting on the connection. :D
yorkylancs
yorkylancs
