Top Yoke
yellowstorm
Top Yoke
Post by yellowstorm »
Will a varadero top yoke fit my 97 Storm? I'm looking to do a handlebar conversion and have the opportunity to get the yoke cheaply.
If not, is it easy to drill the current top yoke and fit some handlebar clamps? If, so what should the spacing be?
I have looked at the LSL top yokes but they're £150 which is a bit pricey.
Thanks all
bikerpiker
Post by bikerpiker »
Hi mate , im not sure about the varadero top yoke.
It is easy to drill the standard top yoke ,no set size for spacing the clamps(risers), its just a matter of positioning them with the bars,and seeing where suits best :!:
I placed a wee bit of roughly 6mm aluminium underneath the yoke at each side, to act as a packer ,where the nuts or bolt heads are.
You will most likely need to cut the fairing,depending on the type of risers you use,there is a type where you dont need to,a few folk on ere has used them ,but those are a bit more expensive. £60 ish.
Some people fit vfr bars if its just to raise em a bit,depending on what year of vfr,u may need to cut the fairing also.
Try doin a search on here, i think i put mine under "risers" or "flat bars" or similar,loads of people have done the mod.
Stevie
Stevie
bikerpiker
Tim,
nah,not gb moto or genmar, i mean those long ones that vtrbob used ,they bolt on to the yoke,but the bars are actually mounted between yoke and tank :!:
Rather than up ,they come back the way,to give the clearance needed between bars and fairing.
Im not sure who makes them ,but they do look dead easy to fit without any fairing mods :)
EDIT... decided to show the type i mean above ,, :)
Stevie
Stevie
pariah
Post by pariah »
I dropped the vfr bars on mine , makes a lot of difference to the ride position . Not much mod to do to the fairing, but had to make an elongated z shapped mounting bracket to hold the front brake line join mounting block . Apart from that straight forward to fit. Pre Vtec model.
bikerpiker
I fitted these ones, angled risers, but had to cut them at even more of an angle ,if i hadn't took the saw to them i would've had to cut a larger chunk oot the fairing :!:
Stevie
Stevie
Richie_Firestorm
Post by Richie_Firestorm »
I don't suppose you've got any more pics of the bars and how close they come to the plastics and the tank?
IT Network Manager and Fish Pimp
bikerpiker
Sorry mate,i don't.
Just a pic of risers on yoke.
With those ones i fitted ,i just kept trimming fairing with a dremmel type tool untill i got full lock either side. A bit of masking tape as a guide.
My flat bars didnt help,if i had used bars that swept back a bit i wouldn't have needed to cut so much away,although it doesnt look to bad.
If i were to do it again,i'd fit the type above (yellow bike).
Bear in mind these were angled risers i used, i had to cut a bit off the bottom or they wouldve been to high,so then i had to drill/tap fresh bolt holes .
If you do a search, "busters bars" , or risers ,i think i posted more pics at the time.
Stevie
Stevie
