Fitted the oiler works well, bit over lubing when dry, in the rain just about right, going to get the controller which you can then adjust the flow abit more precisely. Had it routed differently then changed mind as worried it could have come in contact with chain.well recommended as this is electric powered rather than vacuum. Used the light circuit for power.
