Ok, it may have been asked before, but i couldnt be arsed to search.....
anyone ever fitted a 190 section rear tyre to a standard set up......????
what was it like? did it run ok, did it make much of a difference? (prolly a stoopid one, but i take it will fit ok)???
Cheers...
Tyre sizes........
- essexbloke
- firestorm_al
- Site Admin
- Contact:
- essexbloke
- Pete.L
Hi Essexbloke.
Yes you will find a difference fitting the 190. I haven't done it on the storm but I have on other bikes. I doubt there will be much difference between bikes as all the one's I've tried it on it had the same affect.
The larger cross section will slightly slow your flickability from side to side but you'll probably have more confidence to wring it's neck(especially coming out of corners). Wear will be about the same as before (funny that.More rubber and all that). The bike will have a different feel to the handling but you'll soon get used to it. Mind you this time of year I can't imagine getting a chance to see if it's an advantage or not.
- essexbloke
