steering head bearings
desborough
Post by desborough »
has anyone got the sizes for tapered head bearings for the storm please ie serial numbers etc, been sorting through a few boxes of bearings at work and came across some tapered ones that look like they might be usefull , cheers
I don't know if this will be any use, but this is the original ball bearing serial numbers for the Firestorm s/head bearings:-
SAC 3055-1
SAC 2647-1
desborough
cheers will try those with hayley bearings , gave them the numbers that wemoto have got listed and they said that they are a bit of an oddball size as usual with most jap bike bearings and seals ,so will see what they come up with on those numbers, they usualy come good on most things tho
I tried to get my local bearing supplier to match them, but in the taper roller instead of the ball bearing type. They came back with "there's none that size anywhere in Europe" so good luck with your search :!:
Stratman
Post by Stratman »
They are cheap enough from M&P aren't they? Why bother b*****ing about. IMHO. :lol:
Stratman wrote:They are cheap enough from M&P aren't they? Why bother b*****ing about. IMHO. :lol:
Paul,
I think DB was only hoping to got hold of the actual dimensions, so he could compare them with the ones he came across at work not purchase any :!:
