954 front wheel
yorkylancs
954 front wheel
Post by yorkylancs »
Hi does anyone know if the blade 954 wheel is the same as the 929,and if the 954 slots straight into the 929 forks.Are the calipers and spacers the same also.Cheers. :D
yorkylancs
Cheers timbo,spot on site that.Turns out that the 929 and 954 wheel are 100% interchangable.Also the SP1 fits but needs the external spacers machining,and bearings changed,as the sp has a 20mm axle the 929 is 25mm.Another option is 1000rr ones but the brake discs are smaller.Cheers again plenty to think about there..bit of research helps. :D
