Dropping forks 5mm to help with running wide problem
Can anyone tell me how to do this - is this done through adjustment on the forks or is it more complicated?
- firestarter1977
Re: Dropping forks 5mm to help with running wide problem
hi.
Its that easy pal. I have a 3mm shock spacer and have dropped yokes 6mm. All seems fine. Although i may raise the rear more when i get a few more oiler in on it. But for now it aint run wide on any corner yet
the thunder rolls on!!!
