what do you do if its running lean
ozzie9962
Post by ozzie9962 »
my bikes running lean what do i do,to make it right cheers john.
leanover
Re: what do you do if its running lean
Post by leanover »
how do you know its running lean? have you changed the exhausts airfilter ect?
or do you have a air leak on the inlet side?
a trip to a dyno shop would be the best place to start
btw most std storms run rich
ozzie9962
Post by ozzie9962 »
i av checked the plugs, air filter and hoses. Its on the dyno on monday. £20 at swinton motorcycles so i should find out what it is and i will let u all know then. John
