Thinking caps on fellow stormers
Need to take fork legs out on Sunday to send to Roger for his magic fix.
All you people who have done it before how do you support the bike?
I have a rear padock stand only.
Do I need to remove the yokes?
Keeping it up!
Nope leave the yokes in.
Loosen all the bolts you can first and then just do them up slightly. Then use your rear paddock stand plus a trolley jack (with a small bit on wood on it) under the sump. Be real careful and gentle, if you have loosened all the bolts then it should all come off easy without disturbin the bike stands. A mate one hand would help too (not a rubber one).
Del.
Del.
