More importantly i then moved on to check the bolts around the crank case/fly wheel cover and some of them were worryingly loose (no leaks or broken seal though
A cigarette later
If they sheared then they probably weren't too loose and they only sheared when overtightened? Did you have the right torque settings?More importantly i then moved on to check the bolts around the crank case/fly wheel cover and some of them were worryingly loose (no leaks or broken seal though ). I went to tighten them and promptly sheared two off.
