My bike is currently Idling at 1,200 Rpm or just over when at temp. this seems a little fast
what is the best rpm to have the bike idle at?
i cant remember what it used to be set to before i got the bike back from the mechanic's carb sync up and re-timing of my engine.
Idle Speed.
Idle Speed.
Re: Idle Speed.
1200 is about right. I always think tha "idle speed" means sitting in the back of a Bentley doing 130 down to the South od France with a glass of Moet in one hand and an eager supermodel in the other. Maybe I have an overactive imagination......
Re: Idle Speed.
I would say that's about right. Mine is set at around the same... any less & it's more likely to stall when you are sitting at the traffic lights
FYI the users manual recommends 1,100rpm +/- 100rpm
Hope this helps!
cheers
John
Hope this helps!
cheers
John
Re: Idle Speed.
1200 is right...as above start going lower and u risk cutting out..
