Braided Brake Lines
Braided Brake Lines
I would like to change the front brake lines to braided, should I do a straight swap with a three line set or should I use a two line over the fender kit. I assume the latter will have a speacial banjo to join the master cylinder.
Re: Braided Brake Lines
I've not heard of many fitting braided hoses in the standard set-up of three hoses. Most I would say go for two hoses, both from the master cylinder which requires a longer banjo bolt at the master cylinder. I have known a few to fit one hose from the master cylinder to the caliper, then both calipers linked with a shorter hose going up and over the front mudguard as you mentioned. To do that a longer banjo bolt would be needed for one of the brake calipers.
You'll get arguments for both of the two hose set-ups I've mentioned as to which is the best. So the choice is yours. I personally (when I do mine) will use a two hose set-up, both coming from the master cylinder.
The most important thing when buying stainless steel hoses is NOT to buy any (for road use) with alloy fittings
Mine came with three braided lines on the front, and I'd recommend the two-line version.
With three, you have to undo the little junction box by the headstock whenever you want to lift the RH clip-on off the fork leg.
It's just annoying, and a two line kit wouldn't need this.
Finally got round to fitting a branded 2 line. Very easy to fit but a pain to bleed.
did you hold the last caliper up so that air bubbles could escape, or try to do it on the wheel?
