Odometer question
JohnD
Odometer question
Post by JohnD »
Hey folks
Finally got round to fitting my +2 Tooth rear sprocket yesterday :D
Now I realise this will put my speedo out a bit, but what about the odometer will this be affected (i.e. is it measured at the same place)?
Thanks
John
Stratman
Re: Odometer question
Post by Stratman »
As far as I know the answer is, yes it will.
kevg
Post by kevg »
have a look on ebay for speedo healers, that should sort it out. i'm sure there are a few folk on here got them and can give you advice.
cheerz
kev
Never mind That!!!
What do you think?.... Have you pinned it yet? :biggrin
JohnD
Post by JohnD »
Timbo wrote:
Never mind That!!!
Good man!! Straight to the bit that we really want to know about :biggrin Sod the speedo, is it good fun to ride?
LOL - yeah sorry I neglected the important bit eh!
Had a good blast on it on sunday... & yes it's a great mod! Acceleration is loads better, front wheel comes up much easier than before, & it handles better too (as wheel base is shortened). Only downside is that I found I was dancing round the gearbox more than before... but am sure i'll get used to that! :o
balls
Post by balls »
Hi there
I would like this to do this mode as well as the bike is a pain to ride slowly around town and top gear feels to tall , Where did you get your sprocket from and how much was it.
All the best Neil/balls :D
JohnD
Post by JohnD »
Hi
Got my sprocket from wemoto for around £25 inc postage i think
http://shop.wemoto.com/index.dyn?oid=25299
(see chain & sprockets section about half way down)
:D
John
JohnD
Post by JohnD »
Oh yeah, in case anyones interested, I worked out that my odometer is overreading by around 4-5 miles every 100 which I can live with !
bandsawman
Post by bandsawman »
I was told that the usual mod to do on these was to go down one tooth on the front (and that'd only cost about £6)?
Going anywhere in a car is a journey, going anywhere on a bike is an adventure!
Right enough, but it wears the chain out a bit quicker.
jambo
Post by jambo »
tony.mon wrote:Right enough, but it wears the chain out a bit quicker.
what about one down on front and one up on back?
read that it is good for the cct's,is this true?
mwross1964
Post by mwross1964 »
yeah prey tell someone!
save puttin on manual (as ape)
anything with wheels or tits is gonna cost ya money.
but who needs money
I think you can throw that idea in the "wishful thinking" bucket :wink:
Agreed.
The point about the chain wear is that you're asking the chain plates to bend a wee bit more relative to each other each time they run round the front sprocket, as the diameter's smaller.
It's the smallest sprocket that affects this, the bigger one has much less effect on the angle that the plates are to each other, assuming that the teeth are in good condition.
But the rear one wears the chain in a different way; with the larger sprocket, the more links are in contact with the sprocket at any given time, and as the chain wears it puts sideways pressure on the tooth profiles- that's why an old chain fitted to a new sprocket knocks it out in double quick time.
I can't see any advantage to the CCT's- all that will happen is that the gearing change means that for a particular road speed you'll have slightly different revs.
Now this would be good for the CCT's and cam chain wear if your revs were lowered all the time (although there are effects elsewhere- increased cush drive wear, gearbox wear), but in practice all it means is that you'd change up or down a bit sooner or later to compensate.
It's really only flat out in top that you'd see a permanent difference; the rest of the time you're going up and down gears and up and down with the revs all the time you're riding.
Standard gearing: 16/41 = reduction of 2.5625:1
Your option : 15/42 = reduction of 2.8:1
popular option : 15/41 = reduction of 2.7333:1
larger at rear : 16/43 = reduction of 2.6875:1 (but longer chain probably needed)
You choose! :D
Lastly, it's worth mentioning that there's only so much clearance with the chain run to the exhaust pipe as it runs from right to left beneath the bike.
Fitting bigger sprockets both ends would mean that the chain starts fouling it.
God. you can really get anal about this stuff, can't you? :biggrin :biggrin
