Belly pan
pariah
Belly pan
Post by pariah »
Helloooo There.
Had to remove the lower belly pan to replace front sprocket, just my luck for one of the side mounting brackets to go and snap off :cry: . I belive it,s a power bronze pan. Any one know where or If I can buy a new sid emounting bracket for it please. :?
Rick
Re: Belly pan
You should be able to just get a welded-on repair cheaply, or find someone with a welder locally on this forum.
You probably won't be able to see the bracket once the belly pan's back on, so it doesn't have to be neat.
The good thing is you can still ride your bike to the welder's!
