WP shock on e-bay
WP shock on e-bay
Spotted this on e-bay, if it goes for less than £100, it could be a good upgrade.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :middle:uk
It is the same model of shock I use, but mine has ride height adjutment, so you will still need shock spacer with this one. It only has rebound damping adjustment, but there are 12 clicks and it has a real effect.
The one for sale looks a bit tatty, but they are fully servicable, about £60, and the spring can be powder coated for next to nothing.
Main thing to check is that the spring rate is correct for your weight, as a new spring costs about £80...............That is the mistake I made when I got mine 2nd hand, but at least I now have a shock that is custom set up for me!!!!
Also I should add that you want to spend the £200 to have your forks done before you spend money on the rear, as the front is the biggest weakness.
Roger at revolution racing will give you an idea of what spring rate you need for your weight, and the original one should have a number written on it. I think the one i bought was a 165 spring and that was far too hard. I ended up with a 140 for 13st weight.
PS I have no connection with the seller.
Re: WP shock on e-bay
Cheers for that.
I am bidding on the off chance I keep the Storm.
- Phil-VTwin
Soooooo it was you that outbid me, i was hoping no one would notice it was a WP
Ride Safe
Phil
Phil
sorry you 2, I guess you didnt wants everyone seeing it!!!!!!!!!!!
Now there will be a Forums bidding war.........you will need a gentlemans agreement
Exactly my thoughtsAMCQ46 wrote:Now there will be a Forums bidding war
We've been here before I seem to remember...
SP1's rock!
- Phil-VTwin
Well I have bid as high as I am going to, which is not that much tbh.
If I win, I win, if not then I am not bothered
Jbrebel wrote:Exactly my thoughtsAMCQ46 wrote:Now there will be a Forums bidding war![]()
Heh heh your not wrong
That's me out
Spring rate looks like its for the larger gentleman
- bikerpiker
Average....13st ???....cheersAMCQ46 wrote:yup 160 165 spring is way to hard for the average 13st
Stevie
- Phil-VTwin
