Mini Indicators
seb421
Mini Indicators
Post by seb421 »
now i have two trashed indicators I'm toying over the idea of 'mini' replacements, has any one got these fitted?
i haven't got a clue about wires and relays etc so not sure about LED's so just been looking at standard bulb models atm
Ive found these on eBay but they look a little cheep with the screws in the back etc, any one seen these before?
http://cgi.ebay.co.uk/97-06-Firestorm-V ... otohosting
blacknek
Re: Mini Indicators
Post by blacknek »
hi seb, Iv had a pair on the back.. its no probs just follow the wires to each indicator and into the same socket
ed
Mick B
Re: Mini Indicators
Post by Mick B »
Ive just ordered the same set and awaiting arrival :thumbup: Just change the screws to black and you should be ok fella. :mrgreen:
Jbrebel
Re: Mini Indicators
Post by Jbrebel »
You'd only need to play about if they were the LED micro indicator types. They'll be fine just plugged in like blackneck says.
Screws are present on most. You'll be able to access the bulbs or sort out any condensation should it occur-edit-just make sure you fit them the right way up. Most have a cut out that should be at the bottom of the lense case when fitted. It'll allow any moisture out. If its at the top it'll let water in :thumbdown:-edit
They look nice :)
SP1's rock!
seb421
Re: Mini Indicators
Post by seb421 »
im aware that these are plug and play and not led because i wasnt looking for led as i didn't want to piss about with resistors and relays etc , i was just concernd about them being a bit crap
i think i shall make a purchase and see how i get on, just worried they might look naff
Jbrebel
Re: Mini Indicators
Post by Jbrebel »
Fair enough Seb-no they don't look crap :D
Enjoy your indicators :thumbup:
SP1's rock!
seb421
Re: Mini Indicators
Post by seb421 »
Mick B wrote:Ive just ordered the same set and awaiting arrival :thumbup: Just change the screws to black and you should be ok fella. :mrgreen:
hi Mick B i paid for mine on the 31/07/09,
do you have any idea of your delivery time? i left a message with them but no response as of yet
Re: Mini Indicators
I can't see how they're off a mini, they look nothing like the ones on my mate's Cooper.
Maybe an import?
Mick B
Re: Mini Indicators
Post by Mick B »
Well the indicators came after a weeks wait from Japan. Regular tracking info was supplied and the build quality was spot on. The only thing is the front set are a tight fit due to the short stems but once fitted they are spot on. Well worth the money. :thumbup:
Stratman
Re: Mini Indicators
Post by Stratman »
My rear mini indicators were quite dull as they had no reflector. Bit of bacofoil sorted it out
seb421
Re: Mini Indicators
Post by seb421 »
well fitted the mini indicators today I bought, the ones in the pics above and as I thought there sh1t!
the front are as tight as a nun's snatch (possibly tighter as there pulling on the fairing to get them tight),
and all four are as bright as a spastic, and the spacers....lets not go there!
needless to say i have removed them and fitted the busted original until I get another from a breakers yard and will be selling the mini's on ebay
Mick B
Re: Mini Indicators
Post by Mick B »
seb421 wrote:well fitted the mini indicators today I bought, the ones in the pics above and as I thought there sh1t!
I thought the build quality was good. Yeah they are a tight fit on the front but look spot on compared to original indicators. I thought they were bright enough but not as bright as the big Honda jobbies. No complaints really each to their own.
Re: Mini Indicators
Seb,
I thought they looked fairly good in the pic's so I'm surprised you're not happy with your purchase too.
I thought the little window at the back of them was a nice touch.
I know different people have different ideas at what is acceptable etc and what is not, but which part of them did you not like :?:
seb421
Re: Mini Indicators
Post by seb421 »
I didn't like the fact that they just wasn't bright at all
and the fact that they was that small to do the nut up it was pulling noticeably on the fairing, the build quality was ok not knocking that but the item is never for a fire storm, it looked horrendous when fitted this tiny thing that didn't fit properly and had a massive gap behind it looked stupid and was very dim.
the spacer's to was a joke.
im going to be fitting the indicators off a later model firestorm and cut the box off the wires and put the end's on from mine.
Re: Mini Indicators
Seb,
So it was really down to not being very bright, something you could only find out by giving them a try I guess.
May be brighter bulbs would have helped, plus you can get covers that cover unsightly holes that are normally showing with smaller type indicators, including LED types.
Better luck I hope with your next option :)
