R6 regulator rectifier
Mick B
Post by Mick B »
Sorry to be a pain but just won this item off eBay. Is it the correct one for the storm.
Item number: 180396805566
Jonesey
Re: R6 regulator rectifier
Post by Jonesey »
Yup, that's the puppy!!
Good mod this.
Chris. :thumbup:
Unus Dies Gingiber Mos Hereditas Orbis terrarum.
Mick B
Post by Mick B »
Cheers Chris. Got it for £22 all in delivered so well happy with that. Even though my RR is working it's always in the back of your mind it may fail at any time.
That's more like it :thumbup:
If you've not already seen it there's a wiring how-too in this link:-
http://www.vtr1000.org/phpBB3/viewtopic.php?f=31&t=5308
Mick B
Post by Mick B »
Cheers fellas helpful as ever :thumbup: :clap:
Mick B
Post by Mick B »
Ok the regulator rectifier has been changed. It only took 30minutes and was hassle free :thumbup: rather than chop the original wires I just un hooked the spade connectors from the plug and pushed them straight onto the R6 unit. I am getting a healthy 14.2 at the battery on tick over but have a minor issue. Just a daft question I lost my stand down light after this mod and thought it was related but how can it be ?. Anyway I went to go and test the bike on the road and with the stand up I put it in gear and it cut out :eek2 The safety feature seemed to working in reverse.I was just about to strip the bike again thinking what have I done when the warning light flickered. I then fiddled with the stand and all appears to be ok for now :shh: . One question though how much movement is on the stand when down.ie stand the bike up and wiggle it backwards and forwards(rear brake to gear selector) mine seems to move a lot as if spring loaded is it lose and causing the problem.
bikerpiker
Post by bikerpiker »
SNAP--Myself and someone else had similar problems after fitting a new reg/rec , have a look at this, and how i sorted mine ----------
Clicky-- http://www.vtr1000.org/phpBB3/viewtopic ... nd#p108147
Stevie
Mick B
Post by Mick B »
Cheers for that Stevie. So it's just bad luck and nothing to do with the RR ? Anyway it all seems to be ok now so don't know if I should fiddle as I may make things worse. :eh:
