chain length with extra teeth
chuxsta
Post by chuxsta »
about to order 2 teeth up on rear sprocket
what length chain is needed?
if some one else has done the same will save me the time counting the links..
Jonesey
Re: chain length with extra teeth
Post by Jonesey »
Hi Chuxsta, when I did this, it was standard+ 4 links, but if you've got a hugger fitted be careful cos the tyre can rub under full adjustment.
Unus Dies Gingiber Mos Hereditas Orbis terrarum.
You can still use the standard length chain with a +2 on the rear. But remember the adjustment markers will be well out, as the wheel will be almost as far forward as it will go in the swingarm.
