new battery required
Drac
Post by Drac »
Sadly i haven't had sod all time to ride the bike for god knows how long.
Since the MOT last year i reckon ive only put 500 miles on it, anyway to cut a long story short the battery is fecked. Anyone used tinterweb to order a replacement?, local car/cycle motorbike place hasn't got one in they say will fit.
Any reccomendations as to what to avoid or who from is appreciated.
Re: new battery required
Personally if you're intending to keep the bike for a few years I'd go with an OE (original equipment) replacement which is a Yuasa. The link below shows one for the earlier Firestorm. The later model (19ltr petrol tank) had a smaller battery.
Make sure you check your battery code first (it'll be on your battery) before ordering so you get the correct one :?:
http://www.mdsbattery.co.uk/shop/produc ... roupID=838
If you still won't be using your bike very much then invest in a motorcycle battery charger/moniter, otherwise you will need another new battery next year,
Drac
Post by Drac »
Ta Sirch
A lot depends on how long i spend in las Vegas and what the weather is like in between those periods.
but ta for link mate
