Noticed tonight that with bike on tickover, one exhaust was significantly hotter than the other.
Looking at the back, the left was hot, right cold.
Is this normal or does it indicate a problem?
Cold exhaust
Re: Cold exhaust
Standard exhausts?
What part of the exhaust feels hot / cold?
Does it feel like there's an equal amount of flow out of each can?
Could be such things a partial blockages caused by collapsed rusty baffles, packing dissappeared.
Not sure if the left one flows more gasses from the rear cylinder and the right from the front but if that's the case then maybe spray a bit of WD40 or water on the header pipes close to where they exit the cylinders and see if the steam off equally maybe a misfire could cause what you're getting.
Re: Cold exhaust
If it's the end can that's cold then thats normal. Both exhausts flow different amounts as it's not a true 2 into 2 system (assuming a standard system), it's more 2 into 1 for a little bit, into 2.
Rich.
Re: Cold exhaust
With the exhaust silencers off you can look down into the RH side pipe and see that there's a significant obstruction from the way the pipes are joined.
This makes it easier for gases to flow into the RH pipe than the LH one, so more gas flow to the LH and it gets hotter quicker.
Some threads in workshop section re whether this is best left alone or removed.
I cleaned mine up with one set of downpipes, but they broke up so I put a new set on, haven't bothered grinding these out yet.
Will do one day, though, as it evens out the power pulses going into the carbon cans and doesn't seem to break them up as much when there's less resistance.
That's the theory, anyway, but to be honest carbon cans on a big twin are just consumables when it comes down to it- they'll never last very long.
