Hey people me again
Got my Storm back together after sorting CCT's etc
I got her fired up and she was on the button first time but when i took her out for a spin she was struggling to get revs at top end
Ive given her a complete service so i know its not that .
I had a similar problem on my old Rd350ypvs years ago that had water in the tank and it run like a dog for weeks before it cleared
i did however notice a breather vent on the injectors was cracked (could this be the problem ?)
Im guessing its one of these things
1:Breather tube damaged/incorrectly fitted
2:Water in the carbs/tank
3:breather on injectors
I followed the instructions very well for the refit of the breather tubes etc last time i had her back together
This is the last thing i need to sort out before i sell her as ive got my new bike now 8o)
Possible Air leak help
Re: Possible Air leak help
Have you had the tank off
if so did you put the vacuum pipe back onto the correct fuel tap outlet at the back of the tap (nearest to the battery). It should be ( using a clock face for discription) in the 9 o'clock position and not the 6 o'clock
yah just checked that one all good baffling me
Just run the carbs dry and problem solved
thanks
thanks
Glad too hear you've fixed it
So was it the vacuum pipe in the wrong position after all
