Crack in engine cover
bogof
Post by bogof »
Right side engine cover slid along the road a few weeks back, and appears to have a small crack at the bottom.
Not been able to check for oil leak yet due to having one arm out of action.
Until I can find a replacement, anyone have experience of sticking something over such a crack to stop all the oil falling out? If so, what did you use and is it best applied on the outside or inside?
cupasoop
Re: Crack in engine cover
Post by cupasoop »
Halfords sell "liquid metal" that i've used to cover a hole in an engine casing. Kept it oil tight for about £4.
Rich.
tonyb
Post by tonyb »
chemical metal is pretty good stuff always take some on track days with me used it on casings before and even holed radiators works a treat, always in stock at halfords
tony
Jazzscot
Post by Jazzscot »
+1 used it on my engine casing and it works braw :thumbup:
Jazz
Everything good is bad
Everything bad is good
bogof
Post by bogof »
liquid (chemical) metal it is then... halfrauds here i come :)
Thanks for the advice 8)
gilson
Post by gilson »
Surprisingly, Silicone sealant works too (especially the head/rocker gasket sealing stuff (Wurth is good)). Maybe not a permenant fix, but lasts well enough...
I've got some carbon covers to cover the scratches up, they are not cheap (but nothing carbon is! 89 Euros I think).
carbonadi1@yahoo.de adi is the chaps name, from Germany. They are good and I've crash tested them on track and they take a slide well... (not to mention look good!)
No bike (yet).
