Ok, here we go.
First all the indicators stopped working along with the horn and rear brake light...easy fix, one blown fuse.
Next day same thing happened... again easy fix, new fuse but now concerned as to the cause.
Next day same thing but i only had a fuse which was 10amp to high on me (i know) but this sorted the problem.
Now the indicators on the left work, the horn works and the brake lights work but the indicators on the right dont work but the when i put them on the main light and rear light flash....
What do you all think i should do.
Gary
Indicator problems
- stormingjoe
- Contact:
Re: Indicator problems
you have a short somewhere prob in the indicator circuit for that side, check the bulbs are not faulty, had a few lately shorting out inside the bulb itself
