All the best Balls
So going by your experience Chaz this battery (NOTE: Neil (Balls) this is the battery used in the later Firestorms which is approx. 20mm lower in height) should be a good pricechaz wrote:depends what you call a good deal, Im selling Rob Hunters for £30. but can get Exides or Gel but are dearer.
If you get 3 years out of a cheapie thats about it, if you can afford it get a Gel one and the better the cold cranking amps the better but expect to pay £75
Neil,balls wrote:Did not know there was a top cover to the battery box looks like mine does not have one LOLdo you know the code for the varado battery Chris .
Neil,balls wrote:I have a feeling that the old one that came with the bike was a ytx14 that's why the battery cover is missing and I still have the old one in the garage will have a look tomorrow , the 14 is about the same price as a12 to. So it looks like I will get one of those![]()
All the best Chrisfor the help
Neil, so does that mean you had a standard size (YTX12-BS) battery in it after allballs wrote:Well its in and running ok had to find a little bit of slack for the - cable but only a few mm so a good easy upgrade
The battery you have bought will have been dry charged and will have a shelf life in that state. You could ask the supplier how long that shelf life is.insider wrote:Looking to change mine as well.
I ordered a Yuassa. I wanted to cancel the order the last minute,but was too late.( i had realized too late that i had more important things to spend money,besides the battery,since the current one still works)
The yuassa has arrived, it's at the service shop,but i'm gonna install first thing in spring. I don't think there should be any issues if i keep it like that until then (it's not mounted on the bike yet).
