Brake Caliper Piston Seals
mannock18
Post by mannock18 »
Hi, Can anyone help? I have to strip down my front calipers and replace the seals. I've browsed the net to find a good place to buy the kit and am confused now as there are two sizes offered. They are 27 or 30mm. My 'storm is a '97 model and both kits are offered for the same year model. Was there different types of caliper fitted. Any help greatly appreciated!
Phil-VTwin
Re: Brake Caliper Piston Seals
Post by Phil-VTwin »
Welcome to the forum,
The calipers have different size pistons which is why you need different seals, i did mine last year with a kit from wemoto which included everything you need.
http://www.wemoto.com/bikes/Honda/VTR_1 ... r_-_Front/
Ride Safe
Phil
mannock18
Post by mannock18 »
Cheers Phil and thanks for the welcome. Is there any way of finding out what size seals I need other than measuring the pistons. I need to keep the bike on the road until I get the callipers off. Its my only transport.
Phil-VTwin
Each caliper has 2 x 30mm and 2 x 27mm pistons so that kit will have everything you need to replace them all.
You should be able to do them both in half a day but read the postings in this forum about bleeding the system!
Ride Safe
Phil
mannock18
Post by mannock18 »
I see…it all makes sense now! I'll get the parts ordered in the morning. Thanks for your help Phil
Most importantly,
check the groove where the seals are seated. You can get a load of crystalized crap build up in there and you need to give it a good scrape to clear it all out. If you leave any behind your brake pads can drag and you might warp a disc.
Have Fun
