Hi All
Can anyone tell me if it's worth buying a K&N air filter and if so would i have to do anything to the carbs or can i buy it and stick it straight in....i'm not mehcanically minded at all and i couldn't remember if someone said i had to get something done to the bike if a stuck the K&N in???
Also i'm doing a Charity Road trip in August for 4 days and i will have the chance to hurtle around the Nurbergring, i'm doing a service on my bike (oil filter, oil, air filter, spark plugs, manual tensioners, brake pads) at the moment, is there anything else i can do to her before i take the trip??
Any advice would be greatly appreciated!!
K&N Air Filter
Re: K&N Air Filter
I was thinking of getting my tyres changed just before i go anyhow......so would you recommend sticking with the standard air filter then????
Re: K&N Air Filter
LOL....I look forward to meeting them!!
Re: K&N Air Filter
Let's get this party started.....
i use a K&N, but combine it with straight-through ex's and a jet kit, all set up on H&M racing's dyno. Oh, yes, and the two long bellmouths and an ignition advancer.
No fuelling issues now!
But I would have thought that if you run std ex's and just change the air filter it'll upset the fuelling a bit, until/unless it's reset on a dyno.
Re: K&N Air Filter
Am I right in thinking you can improve mpg by changing the air filter? Does it have to be in combo with a certain type of exhaust?
- Contact:
Re: K&N Air Filter
Ive got k and n , dyno jet kit and open cans on my vtr, runs mint!
Col
Col
Bikes ftw!
Re: K&N Air Filter
This will show my bright side but what is a Dyno Jet??
Re: K&N Air Filter
chris1bev wrote:This will show my bright side but what is a Dyno Jet??
Erm the cousin of dyno Rod.
Re: K&N Air Filter
It's a way of tailoring the jetting and needles in the carbs so that you get more power.
See:
http://www.dynojet.co.uk/
If you want a freer-breathing engine with less restrictive (but usually louder) cans and a filter, the jetting is best adjusted to take into account the engine's changed needs.
This keeps the fuel/air mixture (stoichiometric ratio) correct. You get more top-end power and torque, typically 5-10 BHP. Noticeable, but not earth-shattering.
The kits come with a "recommended" setup tailored for your bike, but you can then fine-tune the results on a rolling road, or "dyno".
That, with a good operator/fitter, result in the best performance you can get from your engine.
You can also tune for better fuel economy, but with a Firestorm you might as well forget it and buy a CG125 as a spare. You'll never get much more miles/gallon than everyone else- about 30mpg.
Why not find someone locally who's had it done and ride both bikes back-to-back?
See:
Re: K&N Air Filter
I had one on my Storm. It also had a jet kit fitted & pipes.
I never had an issue with the setup-the bike always had an airbox cough from day one.
I know when Lee67 got the bike off me after he swap the filter back to an OE one. He did'nt like the K&N setup at all-I'm sure he'll be along at somepoint to digress more
I've just had one on my Buell with no issues either-as long as it was kept clean/oilded it worked A1. Plus I did'nt have to buy a new filter come service time (which is every 1500-2000 miles on a Buell
Each to there own I suppose
Up to you sir
SP1's rock!
