exhaust
terryfranks
exhaust
Post by terryfranks »
Image[/img]
Converted my storm to a single exhaust. Sounds good and runs fine. What do you reckon?
Re: exhaust
looks great - how much????
youtube a soundclip for us?
Jbrebel
Re: exhaust
Post by Jbrebel »
Have you had it run up on a dyno?
Looks nice :D
SP1's rock!
terryfranks
Re: exhaust
Cost £5 for an end cap for the left exhaust from a local engineering firm. I have just installed a dynojet kit myself and used there recommendations for the setup. First impressions bike pulls strong through out the rev range with no flat spots.
Mid range feels a lot stronger. I will get it on a dyno soon and let you know the figures.
Image[/img]
seb421
Re: exhaust
Post by seb421 »
A friend of mine a good racer, Julian Tiltson Raced a storm last year, He ran a Single pipe set up, His Dad has a Motorcycle Shop and Garage and they know what there doing with tuneing etc, i dont think the bike ran as well on the single set up as with two cans, it was defo louder and pulled hard from the bottom tho.
Jbrebel
Re: exhaust
Post by Jbrebel »
I'm definatley interested to see the dyno results :)
SP1's rock!
Re: exhaust
If I'm honest I like the two can set-up as it looks more balanced IMHO, but your bike looks pretty good to me :thumbup:
I'll be interested to see the dyno results too,
marravtr
Re: exhaust
Post by marravtr »
looks good matey :thumbup: , although i like two me'sen :wink:
mik_str
Re: exhaust
Post by mik_str »
I ran a similar set-up. I cut the header where the two pipes join and mated it to a link pipe (only mod was to cut the link pipe and fit a joiner thus allowing me to rotate one end slightly) and Blue Flame Dual Port can (older version) from a 98 R1 . The bike ran fine afterwards and the jetting set-up (DJ kit) I had with my Micron slip-ons worked flawlessly. On the dyno, it was slightly stonger in the bottom but had a noticeable dip in the torque curve between 4,800 and 6,000 rpm (right at roll-on speed for highway riding). In terms of peak numbers, hp was virtually unchanged and torque was down slightly.
terryfranks
Re: exhaust
The down pipes have not been altered so I can convert back to a standard setup if required.
Re: exhaust
terryfranks wrote:The down pipes have not been altered so I can convert back to a standard setup if required. I did grind out the metal where the pipes split it looked very restrictive. But I think that may have been a mistake; as it might be problem if I convert back wot with back pressure and all that.
That restrictor in the RH side downpipe joint is surely only designed for twin original cans anyway; you'll need to keep the gas flow at full bore to run a single can, as twice the gasflow goes through it.
Restricting the flow further would be the equivalent of restricting the only remaining outlet to around a third to a quarter of standard, too much back pressure for sure IMHO.
Done this mod with straight-through pipes, didn't seem to make any difference either way, really. But can't comment on any effect with STD pipes on, as they only go on mine for a couple of hours a year at MOT time.
If you put the can on the left side you wouldn't need to grind it out.
terryfranks
Re: exhaust
well thats me put right.
