Spark plugs
Spark plugs
What spark plugs are best for the storm
Re: Spark plugs
NGK Iridium
Re: Spark plugs
DPR9EIX-9 NGK Iridium IX,s They seem to suit the V twin, I think there are also SP spec.
Re: Spark plugs
The DPR9 is the best plug I've used, but I have also usrd the DPR8 which is a hotter plug for the winter. I think this is the varadero plug...
As a habit, i change the plugs twice a year, must be OCD.
And as I never throw anything away, have several pairs if you want to try a pair for free.
Let me know.
Let me know.
Unus Dies Gingiber Mos Hereditas Orbis terrarum.
Re: Spark plugs
thanks m8 will pm you a little later. All the best Balls
Re: Spark plugs
I have just put some new plugs in mine......do i have to adjust the gap at all or do they come ready to fit?
Re: Spark plugs
Theyr'e good to go as they are.
Which ones did you use?
Re: Spark plugs
personaly i use a feeler gauge and the recomended setting in the book and adjust acordinglychris1bev wrote:I have just put some new plugs in mine......do i have to adjust the gap at all or do they come ready to fit?
Re: Spark plugs
Iridium plugs need wire type gauges, not the normal flat-blade type.
Entia non sunt multiplicanda praeter necessitatem
Re: Spark plugs
I have blade type gauges and i bought Iridium Plugs......what would happen if the gap was not correct??
- Phil-VTwin
Re: Spark plugs
If the gap was over 1mm then you probably wouldnt get a clean burn. You dont measure the actual gap with platinum or iridium plugs you just make sure your 1mm wire guage can not be inserted.
Ride Safe
Phil
Phil
Re: Spark plugs
Will have to invest in a wire gauge i think.....thanks for your advice guys!!
Re: Spark plugs
Put them in today god what a akward job that was need to have hands of a five year old to get at them . Found the front one was loose so it was good that i did the job fired her up much better the ones that came out where a bit worn she sounds much chrisper now
Re: Spark plugs
I went to Halfords and bought a Spark Plug all angle socket with a handle thingy....can't remember exactly what it's called but that was so much more easier! (i read this back to myself and it just doesnt make sense so good luck with understanding this, lol)
