torque setting
balls
torque setting
Post by balls »
Can anyone tell me what the torque setting is for the rear wheel spindle nut is THANK YOU :?:
yorkylancs
Re: torque setting
Post by yorkylancs »
93Nm so says haynes manual
Re: torque setting
yorkylancs wrote:93Nm so says haynes manual
Equates roughly to "do it up tight with your hand, then you can undo it with your foot"
I'm always aware that if I get caught out away from home the spanner in the toolkit isn't going to cope with too much torque.....
marravtr
Re: torque setting
Post by marravtr »
there's a torque setting??? :biggrin
Re: torque setting
torque setting???
I normally use my grunt meter :wink2
ChrisC
Re: torque setting
Post by ChrisC »
Careless torque....costs lives, :thumbdown:
Re: torque setting
Timbo wrote: Which is why i do mine up using the plasticine spanners in the toolkit and then check it often. No point using stuff you wont have with you in the event of an "issue.
Good rule, I try and follow that one too.
