Front indicators.....
cliveyandrews
Post by cliveyandrews »
I wanna do something about them!
They are huge, I've got some nice slimline ones on the rear....
I'd like to do similar for the front...
Has anyone made a proper packing piece to let you mount aftermarkets to the front (Pauline's are bolted to the carrier inside and sit almost flush, rather than set out)
I have some triangular ones that will flush into the front "intakes" perfectly, but what about the sides...?
I got some LED side markers, but they're oval, not trapezoid...
Anyone seen maybe LED panels of the size that may fit behind...?
Loads of questions I know, but I'm fussy about the look....
Audi, Vide, Tace
Re: Front indicators.....
I used this style, covers the hole nicely, but will need two tiny holes drilling in the fairing fore and aft of the aperture to fit.
http://cgi.ebay.co.uk/Motorcycle-indica ... 500wt_1182
They have the advantage over the cats eye ones of being able to be seen from the front.
Various lens options, clear, smoked or amber, and black or CF finish- Motrax do 'em, I think, but most parts dealers carry them.
But these ones will probably go for a few pounds.
seb421
Post by seb421 »
to keep the honda look get the newer model indicators like that fitted to later storms and the RR3 etc and just snip the clip connector off and replace with the type on your current. job done.
i should probaly fasion my self a crash guard like the above if this promised bad weather tops up soon.
