Jumping outta gear
Jumping outta gear
Hi guys!
Lately when accellerating hard in 1st gear and I go over a bump in the road, 1st gear disengages- jumps out?
What - where - how, can I start sorting this.
Bu the way had a 140km'h prang with the tyre wall Zwartkops-Raceway this past weekend. It was the 5th lap of qualifying, and the left-hander is flat in 4th, marshalls did not display the oil flag, wrecked my race car and start to the championship.
regards,
Gerrit
regards,
Gerrit
Re: Jumping outta gear
Sounds like 1st gear engagement dogs, means an engine out and strip, split crankcases and while you're that far in you might as well check big ends, mains and crankcase bearings, especially the big one behind the clutch, as I've had one of these let go.
Or another engine, if you can pick up one from an accident damaged bike.
Or go up two teeth on the rear (or down one on the front) and just use second to sixth!
No way u serious, the motor only has 15000 kms on the clock, it has nothing to do with the linkages?
kewl lemme ckeck it out, many thanks
- benny hedges
had similar problem on a suzuki and it turned out to be the detent bolt which is basically a ballbearing on a spring - inside the oil drain plug of all places, it was gummed up to crouton with shite.Gerrit wrote:Hi guys!
used to drive me mad til i found out what it was - wasn't so bad going through the box, but i had to hold it in top with my boot to stop it dropping out of gear.
not sure where the detent ball is on the storm box but might be worth consulting the book to see if it's accessible.
cool crash!Gerrit wrote:Hi guys!
regards,
Gerrit
- Pete.L
More importantly
Please tel me this is not your gilrfriend and you are not that Gerrit
[youtube][/youtube]
[youtube][/youtube]
Thanks guys you too kind
Gerrit,
Are you sure your foot is not just lifting the lever when you go over a bump
Pete.L wrote:More importantly
[youtube][/youtube]
Cancer is the cure.
- Pete.L
I watched Gerrits little excapade coming off track last night and that was the next Vid on You tube. Seamed a lot funnier after a couple of Voddies than what it does now
- Pete.L
That's a point!
Hope I haven't offended him!
