just gone to do a simple 20 min job of bolting my belly pan on that ended up taking me 2 hours
one of the brackets bolts on through the starter motor holes unfortunately at some point some heavy handed oaf has had a go at it and snapped one of the bolts and in typical retard fashion left it,
there wasnt enough bolt left to weld a nut to depsite 3 attempts, i then had to drill the old bolt out, next problem was there wasnt enough room to get the handle of the tap in there to re-tap the thread so i had to bugger about around the oil cooler pipe carefully doing it with the tap in the drill
before finally spending 20 mins bolting the belly pan on
another plus point is i had a new pair of pilot road 2s fitted today at substantially discounted rate
roll on 8 tomorrow morning so i can get out and scrub them in,
