re the cct mod, ape ccts will set you back about 85 - 90 for the pair from
elcamin0@aol.com - gary from overstock parts in the usa - mail him direct tbh ;)
or contact bazza here for some of his nice converted ones.
easy enough to fit them yourself if you follow the instructions on here -
Exactly!!!!!!!!!!!!!
a shortcut = a shortfall
if you get the later r/r off a late model storm or blackbird, the finned type, you can jusy plug the original connector in and it might not fail - keep yout old one for spare lol.
if it does fail, it will definately take the battery with it, but could also cost you a cdi unit and other electrical bits.
the least it will do is flatten your battery when you have a hot date.
i don't think you will need to re-jet with just the cans, but if you fit a k&N or similar aftermarket air filter you will.
not sure what you mean by using the rear pegs...
do you mean for stunting lol or for doing the unspeakable act of which we do not speak.... ie a pilliok??
are they high level cans using the pillion peg mounts as hangers?
i'm sure there's a way round it - like swap your cans and link pipes for mine lol
