hi all
after my spill i have decided to replace the rubbish indicators i had for led replacements
what i want to know is what typeof unit do i need and where it fits, am guessing its inplace of the stock unit ?? wheres that located lolol
also how many pins do i need 2 - 3 - 4 ??
many thanks in advance
led indicator flasher unit question
- firestarter1977
the thunder rolls on!!!
Re: led indicator flasher unit question
RH side under the tail plastics, if the front bolts won't come out because the captive nuts rotate in the subframe then you can stretch it out after taking off the rear light and pivot it up out of the way.
Otherwise make sure you get resistors with your indicators otherwise it'll flash at twice the rate, then you can use the original flasher unit.
Motrax do a unit called Flash It - make sure you get the right one though (you want the one for the Honda rather than the universal one), dead easy to wire in, and makes the LED indicators flash at the right rate. About £20 for the unit.
- firestarter1977
