Has my Regulator / Rectifier finally gone kapput?
JohnD
Post by JohnD »
Hey folks
Long time since I've posted on this forum... so apologies for that.
Anyway... here's the problem... had problem starting the bike yesterday... felt like a weak battery, but it finally started. (PS battery was new in winter).
Got home charged battery up, but it seemed was pretty much charged anyway. Put fully charged battery back in bike, and still got same problem - bike just about turns over (most of the time) but just not enough juice to get it going.
So I bought some multimeters, and got my Haynes manual out, and have deduced that the starter relay is fine, so onto the R/R...
Did the Haynes tests for the R/R (Chapter 9.33), and the first one where you measure the DC voltage from the red/white terminal & earth gave me a reading of 12.16v. Continuity on the green wire to earth was ok, and I got a bit confused with the ohmage tests on the yellow wires TBH !!!
So I think the R/R has gone, but would like a second opinion if at all possible please! ...or suggestions of any other easy diagnostic tests (that don't involve starting the bike!).
Also have had a few blown headlight bulbs too during the last year or so... which again makes me think faulty R/R?
Many thanks in advance for any help given!
cheers
John
Re: Has my Regulator / Rectifier finally gone kapput?
just replace it bud, for what it costs it's not worth fkin about.
it'll only let you down when you need it!
get on ebay - 20 - 30 quid easy job
Simple thing I know but have you checked the connection to the starter?
Corrosion & general crapage under the rubber boot?
Mac
SlingVTR
Post by SlingVTR »
Cardiff Motorcycle Limited £30 brand new.
Or use one of the spare reg/recs Jonesy left at my place at the W/S day before last.
I'm in Sevenoaks, North Kent.
JohnD
Post by JohnD »
Hey thanks for all replies folks!
Mac - Yes have checked under the rubber boot to the starter motor & all is ok.
Tony.Mon - have PM'd you fella!
cheers
John
