tl1000r carbs???
tl1000r carbs???
mmmmhh :think: anyone tried doing this????
the tl1000r (pre injection) has 52mm mikuni carbs, while the storm has only 48mm keihins...
keeping the simplicity of the cv carbs, i'm currently pondering trying this.
worth noting that the tlr pushes 135hp
i know it's only a 4mm difference in venturi size, but to put this into perspective, look at the storm's 100hp with 48mm carbs vs the varadero's 70 with 45mm keihins 8O
not a great deal of difference between the 2, the obvious being the venturi size and getting the linkage to work, but can't see it being that big a job tbh...
the cables will be the same so should just be a matter of getting them to sit right using the suzuki framework that holds them together.. then get the jetting right, which should be fun!
any ideas>
theres some on ebay atm, might make em an offer :biggrin
while we're on the subject of fkin about for the sake of it - has anyone given any thought to using the varadero's abs system on the storm? :think:
mik_str
Re: tl1000r carbs???
Post by mik_str »
Unless the UK got something different from North America, the TL-R was never offered with carbs. In facts, its predecessor the TL-S was launched with EFI in 1997.
BTW, venturi size was not the only difference between the VTR and Varadero engines (XLV had smaller ports, higher comp ratio, likely different cam timing and put out 98 hp IIRC, not 70)
made an offer on the carbs anyway - i like playing lol, can't leave nothing alone me :biggrin
http://cgi.ebay.co.uk/SUZUKI-TL1000-R-T ... 3a46ecc4ea
52mm mikuni jobbies cw linkages :thumbup:
mik_str
Post by mik_str »
For your sake I hope the offer is refused because you won't be able to do anything with them unless you embark on a complex and expensive mission to fit the necessary sensors and ECU to use them.....
Played this game a while back, 32mm Amals on a Honda 250 twin G5.
Goodbye tickover, and the petrol blow-back out of the (admittedly lovely shiny) ali bellmouths stripped all the paint off the frame.
kevg
Post by kevg »
How many less miles per tank do you recon you can get from the storm by adding bigger carbs?, lol
cheerz
kev
Phil-VTwin
Post by Phil-VTwin »
Them there aint carbs, they be throttle bodies and no, i will not make you a ECU !!
Ride Safe
Phil
Phil-VTwin wrote:Them there aint carbs, they be throttle bodies and no, i will not make you a ECU !!
+1, you can see the pressure regulators in the photo if you enlarge it, they are FI throttle bodies.
withdraw your bid, or you will have an expensive door stopper for the garage :thumbsdown:
yes indeed you are correct - i'll have to look elsewhere :D
mik_str
Post by mik_str »
indeed, the TL-R was never offered with carbs, as I had alluded to earlier.....
