No Spark
phild
No Spark
Post by phild »
Hi Folks I'm looking for some advice re a problem on a quad bike not my Storm.
I think I have narrowed the cause of it not sparking down to either the coil or the cdi unit with the cdi being fav, but as they want over £250(ouch) for a replacement I need to be sure.
There may be a clue to the fault in that when I leave it overnight and charge the battery to full then try it again for a couple of turns there is a good spark and it will even start for a few seconds then dies and then its no spark again. Have checked all the readings from manual for the electrical tests as best I can but nothing conclusive is showing up.
Have replaced plug and plug cap already!
Its a Polaris Sportsman 335 1998 model if anyone can help?
Cheers Phil
Re: No Spark
try it with a different battery before you go spending silly money.
could be the old r/r failure - it doesnt just happen to storms you know :D
Re: No Spark
phild
Re: No Spark
Post by phild »
Thanks for info Guys,
website was very helpfull Chris, most of the people on it seemed to be in Canada but loads of advice.
Problem was down to stator and not cdi unit, just needed all the crud cleaning out and set the airgap correctly, bike now back up and running.
thanks again, Phil
